Mask Shape From Layer Verticles
Boris Rozhkovsky
on Aug 14, 2014 at 9:53:18 pm
Hello,
i have a 3d layer moving over the frame, for example from left to right, with some rotation. It has squre photo
i want to create a mask, or a shape, which "Shape" property will be "binded" to this moving layer.
So, it`s shappe property must be animated, and in every frame coords of mask verticles must be the same as the coords of layers corners.
Is there are any way to do it not manually?
Walter Soyka
Re: Mask Shape From Layer Verticles
on Aug 15, 2014 at 12:45:00 pm
Mask vertices cannot be addressed parametrically in Ae -- not without a little help, anyway.
BAO Mask Avenger [link] is an Ae plugin which lets you directly manipulate the vertices and tangents of mask shapes.
Walter Soyka
