After Effects: Text Chiseled into Stone?
Eli Sanchez
on Aug 14, 2014 at 5:28:36 am
I seemed to have hit a brick wall with my current project. My client wants to see words chiseled into stone.
Their example was this :
I used this tutorial :
but they were not satisfied without the words being animated
Any suggestions would be greatly appreciated.
-Eli
Anders Hattne
Re: After Effects: Text Chiseled into Stone?
on Aug 14, 2014 at 11:44:53 am
Well you're in luck since the example your client sent you is a tutorial of Andrew Kramer from videocopilot.net.
And since he tends to supply his project files, you'll have your work done in no time!!
Here you go, procedural crumble:
http://www.videocopilot.net/tutorials/procedural_crumble/
The tutorial you provided has some nice trailing sand in the end, I might take a look at that later!
http://www.ardillamedia.com
Eli Sanchez
on Aug 14, 2014 at 6:00:41 pm
Oh sweet this should do the trick!!!
Thank you.
