Camera invert itself. What to do?
Giacomo Tventi
on Aug 9, 2014 at 3:58:06 pm
Hi, i'm new to the forum.
For the past years i've been dealing with a tedious problem: it seems that, if i orbit an after effect camera on its vertical axis, getting a "Top view" of the object, when i past this limit, it ivert itself, meaning that it shows a "mirrored" version" (interted perspective)of the same point of view.
I've reinstalled AE multiple times and serched for this issue all over the internet, without success. I hope some of you can help me out. Now, in particular, that i discovered Element 3d, this is really becoming annoying.
Thank in advance for any response.
Bye! :)
Brian Charles
Re: Camera invert itself. What to do?
on Aug 9, 2014 at 4:27:31 pm
The camera is a 2 node camera, both Position and Point of Interest ( the 2-nodes) need to be animated.
When the Camera crosses the Point of Interest the camera turns to face it.
The solution is to either use a one node camera which only uses position (it's found under camera options) OR to animate the Point of Interest as well as Position.
Giacomo Tventi
on Aug 10, 2014 at 1:42:22 pm
THANKS A LOT! I really wasn't capable of figuring it out by myself. I learned AE by indirect tutorials, and i have never went in-depth with its capabilities. Maybe i'll watch some tutorials regarding AE's Camera. Thanks Again :)
John Cuevas
on Aug 9, 2014 at 8:04:35 pm
Here's a link to a thread that has some links to some good camera tutorials and camera rig setups(makes controlling the camera easier)
http://forums.creativecow.net/readpost/2/1031696
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
