Assuming this ribbon is a 3D animtion, this would be a piece of cake if you had a UV pass. It will require a good amount of careful manual work if you do not.
If you are purchasing a template, it might be easiest to contact the author and have them provide you a UV map, which you could then use with RE:Vision Effects's RE:Map plugin, or simply render the ribbon cutting with your logo for you.
Walter Soyka
Designer & Mad Scientist at
Keen Live [link]
@keenlive [twitter] |
RenderBreak [blog] |
Profile [LinkedIn]
