Composition was scaled up when rendered?
Josh Krauth-Harding
on Aug 7, 2014 at 3:06:01 am
Although I'm not new to AE, I would say I'm a beginner... so go easy on me! I'm guessing I just did something pretty dumb, but I need help none the less!
Recently, I rendered a composition to a .avi and I was met by some terrible quality. This confused me, because inside of After Effects, things seemed nice, and looked good. However, here's a screenshot (using ShareX) I took inside of After Effects of some text:
Here's it in Windows Media Player:
You can tell that the quality of the second picture is lower, while the size is bigger. Perhaps I just wasn't viewing it at the correct aspect ratio inside of After Effects, and if this is the case, how can I change it so the quality looks good once I render?
Thank you!
Graphic/Motion Designer in Training... lots of training.
Tero Ahlfors
Re: Composition was scaled up when rendered?
on Aug 7, 2014 at 8:22:50 am
Is the WMP window the same size as your AE comp window?
Michael Szalapski
on Aug 7, 2014 at 3:44:15 pm
What Tero asked. Also, what were your render settings in AE? What were your composition settings?
- The Great Szalam
