Font symbol's problem
Chris law
on Aug 5, 2014 at 2:19:59 pm
Hello, I've got a font I'm using in my composition and I need to add apostrophe's through out the various text layers, problem is every time I make an apostrophe it defaults to myriad pro, rather than using the font symbol from the font family I'm using. Its definitely in there because I managed to get it to show the apostrophe in illustrator (although even this started defaulting to myraid pro) its just annoying as I can't seem to get around this problem. Anyone have any ideas? Thanks
Dave LaRonde
Re: Font symbol's problem
on Aug 6, 2014 at 7:05:44 pm
Change the font to the proper one BEFORE you make the changes. Or double-click on the text layer to highlight all text, then make the change.
Dave LaRonde
Promotion Producer
Richard Garabedain
on Aug 8, 2014 at 1:32:18 pm
It may also be that there is no apostrophe for that font. You might have to choose a similar, but different font for the apostrophe altogether. Ive done it, Its very hard to notice if done right.
Chris law
on Aug 8, 2014 at 1:35:50 pm
Hey, thanks for the reply, yeah I know you can do that It just annoys me, the font must be corrupt because I've had it happen before with another font and when I obtained a new version of it worked fine. Its kind of weird though because its almost like the font does have a apostrophe symbol showing when you first install it but that must be broken.
