Rotate arrows around circle
Vasik Greif
on Jul 31, 2014 at 4:26:59 pm
I'm trying to do simple 3d animation - rotating the arrows around a circle. I tried to create a path and set auto-orient, but that doesn't work well.
Please see image to see what I need.
How is this done?
http://vasik.net
Brian Charles
Re: Rotate arrows around circle
on Jul 31, 2014 at 5:44:56 pm
One method that will work is to use text arrows from a font e.g. Zapf Dingbats or Wingdings and apply the 3D Rotate Around Circle preset.
7807_arrowsincircle.aep.zip
Vasik Greif
on Aug 1, 2014 at 7:15:18 am
Thanks, that works great! However, I'll need to do the same with logos later - is there an easy way to do this with an image?
http://vasik.net
Quang Nguyen
on Aug 1, 2014 at 12:21:15 pm
I think you can shift the Z anchor point of your 3d layer and rotate it around the Y axis.
Brian Charles
on Aug 2, 2014 at 2:53:55 pm
One option to automate the process is to use the Cylinder script found here to generate single row of elements in a 3D cricle.
http://aescripts.com/create3dshapes/
7810_ringofobjects.aep.zip
Liran Tabib
on Dec 18, 2015 at 9:24:59 am
try this arrow preset:
http://www.vdodna.com/products/arrow-preset/
in the tutorial section of that page you can see how you could bend them in 2D or 3D Space with native effects
