Red Giant Corner Pin; From Pins and To Pins
Iris Moleman
on Jul 29, 2014 at 4:31:25 pm
Hi everyone,
I'm trying to use the 'From Pins' setting in the RG Corner Pin Plugin, but it doesn't seem to have any effect. When I set the 'From Pins' to a shape that matches the part of the image I want to use, the result is the same as when is don't change the 'From Pins' settings.
Am I doing something wrong?
And another question about this...The User Guides says RG Corner Pin recognizes the Alpha Channel of the footage you add. But when I import a Photoshop file with a layer Mask, Corner Pin doesn't use photoshop's Mask.
Screenshot from the user guide:
Thanks in advance,
Iris
Iris Moleman
Re: Red Giant Corner Pin; From Pins and To Pins
on Aug 22, 2014 at 8:50:12 am
Does anyone have experience with the Red Giant Corner Pin Plug-in?
