A "No-Less-Than" expression.
Justin Maloney
on Jul 25, 2014 at 4:26:34 pm
Hey there, kinda new to using expressions. Whats the best way to tell a value not to go above or below a certain value, regardless of what other expressions are being applied?
For example. A wiggle effect on opacity, to make an image fade in and out, that always remains at at-least 50% and wiggles from there.
Brian Charles
Re: A "No-Less-Than" expression.
on Jul 25, 2014 at 4:54:56 pm
[Justin Maloney] "For example. A wiggle effect on opacity, to make an image fade in and out, that always remains at at-least 50% and wiggles from there."
Wiggle can take several parameters, the first 2 are frequency and amplitude. Wiggle uses the current value of a property as a base, so setting opacity to 75% and the wiggle amplitude to 25 would restrict it to between 50% and 100%.
i.e. wiggle(2,25) would wiggle opacity 2 times a second with a range restricted to 25 from the base value.
If you're new to expressions you may want to check out Dan Ebberts site http://www.motionscript.com
Michael Szalapski
on Jul 25, 2014 at 5:47:18 pm
You could always use clamp expressions too.
- The Great Szalam
