Using bevel layer style in AE causes flickering / scintillating
Moog Gravett
on Jul 24, 2014 at 1:43:19 pm
Hi folks,
I'm using the bevel layer style to create some chiseled looking text.
The problem is, when I animate it in a scene, there are lines which kind of dance around the surface making it unusable.
My setup is text in a precomp -> style applied to pre-comp.
I can reduce the effect by making the text rounder, but this is not what I need.
Any ideas?
Cheers,
Moog
Cassius Marques
Re: Using bevel layer style in AE causes flickering / scintillating
on Jul 24, 2014 at 5:08:22 pm
precompose again with "move all atributes inside.." option. Animate this new comp. Layers styles are applied after all transformations so they should allways be pre-comp'd.
Moog Gravett
on Jul 24, 2014 at 8:19:16 pm
Ah, that makes sense. I'll give it a go tomorrow.
thanks for the reply,
Moog Gravett
on Jul 29, 2014 at 3:45:18 pm
That worked beautifully,
thank you for your help Cassius.
Moog
