orient a 3d layer between multiple 3d nulls
Jason McKee
on Jul 23, 2014 at 3:44:37 am
is it possible to orient a 3d layer between multiple 3d nulls. it seems like there should be a way to orient a 3D layer between 3 nulls.
Walter Soyka
Re: orient a 3d layer between multiple 3d nulls
on Jul 23, 2014 at 2:29:26 pm
[Jason McKee] "is it possible to orient a 3d layer between multiple 3d nulls. it seems like there should be a way to orient a 3D layer between 3 nulls."
Looks like a good feature request for keen_3dLayerTools [link] [link]!
In the meantime, try these expressions.
Position:
// applied to the position parameter, this expression computes the triangular centroid of a plane defined by three points
p1 = thisComp.layer("Null 1").transform.position;
p2 = thisComp.layer("Null 2").transform.position;
p3 = thisComp.layer("Null 3").transform.position;
// the centroid is the average of these points
centroid = div(p1+p2+p3,3);
Orientation:
// applied to the orientation parameter, this expression looks down the normal of the a plane defined by three points from its centroid
// the normal vector of a plane is (p2-p1) x (p3-p1)
n = normalize(cross(p2-p1,p3-p1));
// use lookAt to get the orientation necessary to look along the normal vector from the centroid
lookAt(centroid,centroid+n)
Walter Soyka
