Recreating 70s disco funk mv special effects
Nelson Ng
on Jul 21, 2014 at 9:27:30 am
I need to recreate some effects for an upcoming video with after effects. The following link is the reference I have been given.
How can i achieve:
- the psychedelic delay effect as seen in 1:04.
- Glowing and changing colored tint on the trio as seen in 1:44
- Hypnotic flashes behind the two little person on both sides as seen in 2:35
- glowing pink outline as seen in 3:21
Walter Soyka
Re: Recreating 70s disco funk mv special effects
on Jul 21, 2014 at 1:55:09 pm
This is all a lot easier if you are shooting elements for chroma-key. If not, you will have to rotoscope them to get the edge-based effects.
[Nelson Ng] "the psychedelic delay effect as seen in 1:04."
Echo effect, plus Colorama.
[Nelson Ng] "- Glowing and changing colored tint on the trio as seen in 1:44"
High-contrast levels adjustment, plus Tint effect (with changing colors), plus Unmult.
[Nelson Ng] "- Hypnotic flashes behind the two little person on both sides as seen in 2:35"
A few layers, with Fill effect for coloring, plus Blur, plus an Levels adjustment for Alpha only.
[Nelson Ng] "- glowing pink outline as seen in 3:21"
Drop Shadow effect or layer style.
Walter Soyka
John Cuevas
on Jul 21, 2014 at 2:19:06 pm
You could play with a keying and the echo effect, but this was a DVE effect in the 70/80's, not really sure how to recreate.
A glow effect would take care of the first part. Then in this instance some sort of luma key was applied and a the hue was adjusted.
I'd probably just duplicate the layers, use a key, add a blur effect, then a fill effect.
Could be done with the above method, or perhaps just a luma key, with just a glow.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
