AE 12.0...I use before, then I installed AE 12.1 and I got a problem - the quality of video and pictures worse then with 12.0, and I don't know where to start resolving the problem
Lyubov Leahu
on Jul 18, 2014 at 6:55:31 am
Walter Soyka
Re: AE 12.0...I use before, then I installed AE 12.1 and I got a problem - the quality of video and pictures worse then with 12.0, and I don't know where to start resolving the problem
on Jul 18, 2014 at 12:04:13 pm
What do you mean by worse? Can you post a screenshot showing the problem and your complete Ae UI?
Perhaps you just need to check the resolution of the comp viewer? (Lower left corner of the comp viewer panel, can be set to Full, Half, etc.)
Walter Soyka
Jason Jantzen
on Jul 18, 2014 at 7:46:10 pm
Also, you should upgrade to 12.2. But yeah, your post is lacking a lot of information in order to help you.
Jason Jantzen
vimeo.com/jasonj
