Disappearing Illustartor Layers
Scott Crowley
on Jul 16, 2014 at 8:32:48 pm
Hello everyone,
Recently i've encountered an issue while working with After Effects CS6. I have a bunch of layers that i've imported form illustrator to animate. Many of these i've finished animating. I've even rendered some to show the client. Now looking back at the same animation some of the layers seem to be broken. For one comp it flickers in and out but looks masked, The other has the layers but they're completely transparent. I can see the layers they are suppose to be in front of. I'm not using any 3d, and maybe have a few drop shadows.
Anybody encounter anything like this before?
Scott
First pic, is what the weird masking looks like.
Second pic, There should be 3 nuts, all the layers are still there.
Michael Szalapski
Re: Disappearing Illustartor Layers
on Jul 17, 2014 at 1:07:22 pm
I haven't seen this happen (or, if I did, I fixed it relatively quickly and don't remember it because it wasn't a big deal).
What exact version number of CS6 are you using (down to the last decimal)?
Is everything in your comp 3d?
Are assets scaled up or down a lot?
Are you using precomps with the continuous rasterization button pressed?
- The Great Szalam
Scott Crowley
on Jul 17, 2014 at 3:21:40 pm
Hi Michael,
I'm using after effects CS6 11.0.0.378,
I'm not using any 3d in the comp.
Some assets are scaled up and down but I wouldn't say too extreme.
I am using Pre-comps and I'll have to look to see if there continuously rasterized.
What I ended up doing for the time being is I imported the assets again and then replaced each individual layer that disappeared. Took some time but everything seems to be working now at the moment.
If it happens again i'll have to check the continuous rasterization. What problems would that create, if the button was pressed?
Thanks for your response,
- Scott
Michael Szalapski
on Jul 17, 2014 at 4:11:16 pm
Those buttons shouldn't cause problems; I was merely trying to get an idea of how your project was set up.
[Scott Crowley] "I'm using after effects CS6 11.0.0.378,"
You're what?!
UPDATE! You are four big bug fix releases behind. CS6 should be 11.0.4 You are missing A LOT of bug fixes.
- The Great Szalam
Walter Soyka
on Jul 18, 2014 at 12:40:37 am
[Michael Szalapski] "You're what?! UPDATE! You are four big bug fix releases behind. CS6 should be 11.0.4 You are missing A LOT of bug fixes."
Specifically, many bug fixes related to the new cache feature in CS6, which can manifest in some strange ways.
Walter Soyka
Scott Crowley
on Jul 18, 2014 at 2:07:43 pm
I didn't realize I was behind by so much I'll start the update right away!
Thanks Michael for all your help.
- Scott
