How to loop 2 PNG frames in AfterEffects?
Nikola Tomic
on Jul 16, 2014 at 6:15:26 am
Hello guys
I am trying to loop 2 PNG frames like in attached example / printscreen through entire timeline?:
I've tried TimeRemap but it does not loop frames...
John Cuevas
Re: How to loop 2 PNG frames in AfterEffects?
on Jul 16, 2014 at 1:03:48 pm
Is it a single frame, you are trying to loop? Can't you just make it a freeze frame then?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Nikola Tomic
on Jul 16, 2014 at 1:14:34 pm
Nope it has two different frames. I want to loop 2 different images/pictures. Or 4, whatever.
Brian Charles
on Jul 16, 2014 at 1:43:18 pm
Add another KF for the loop. So if KF 1 is frame 0, and KF 2 is frame 1, KF 3 repeats frame 0.
See:
7748_loopedtr.aep.zip
Dave LaRonde
on Jul 16, 2014 at 3:25:05 pm
Here's a dead-simple way to do it:
  • Go to the out point of the second layer.
  • Make it the end of the Work area by hitting the n (for eNd) key.
  • Use the Trim Comp To Work Area command.
  • Highlight the comp in the footage pane.
  • Open the Interpret Footage settings.
  • In the looping section, type in the number of times you want it to loop.
Done.
When you add it to a new comp, it loops.
Dave LaRonde
Promotion Producer
Nikola Tomic
on Jul 16, 2014 at 11:23:04 pm
Well to me interpret footage is not selectable here. It works only on short videos or gif animatons. Not for composition I create here... :( Later I will try to understand this excellent example that actually works attached in previous email :) Thank you guys very much!!
