Having trouble with the video copilot plugin Twitch
Rafael Ribeiro
on Jul 14, 2014 at 6:58:21 pm
I have this composition with a red solid in 3d space using the twitch slider ( rgb split) on it and even though I can see the effect taking place, there's one frame that doesn't render and the preview stops. If I turn off the effect, the composition will render properly. Any idea what might be causing this?
Dave LaRonde
Re: Having trouble with the video copilot plugin Twitch
on Jul 14, 2014 at 10:58:34 pm
Is the red solid the ONLY footage in the comp? Knowing the nature of other footage in it -- especially footage like mp4 / h.264 / AVCHD -- would be helpful.
Dave LaRonde
Promotion Producer
Rafael Ribeiro
on Jul 14, 2014 at 11:40:03 pm
I'm only using solids and an illustrator file in the composition ( also, a light, camera, etc, but all things provided inside after effects).
Michael Szalapski
on Jul 15, 2014 at 5:03:18 pm
What version of AE are you using (down to the last decimal)?
- The Great Szalam
