How many FPS with Twixtor would this be?
Lane Steve
on Jul 13, 2014 at 11:22:28 pm
I shot in 59.94 fps...Then put it in After Effects and interpreted it as 24fps
From 24fps I put twistor then after changing some settings, I set the speed to be 5%.
What frame rate would this be simulating?
If I am correct, I should take the original frame rate (24fps) then divide by by 5% (which if 1 is 100, then 5 would be .05)
So my frame rate should be.... 24/.05=480
But this looks much slower than 480fps. Did I calculate this correctly, or am I wrong?
Darby Edelen
Re: How many FPS with Twixtor would this be?
on Jul 14, 2014 at 4:02:33 am
Your original source frame rate is not 24fps it's 59.94fps. When you interpret it at 24fps it's creating a slow motion effect, then you're adding more slow motion using Twixtor.
Substitute 59.94 into your equation and that should be about right.
59.94 / 0.05 = 1199fps simulated source frame rate
Darby Edelen
© 2018 All Rights Reserved
