How can I change a Composition and all the layers and comps inside it to the same duration.
Joshua Chaulk
on Jul 10, 2014 at 7:07:17 pm
I've imported a character I made in photoshop as a composition and there are multiple comps and layers inside the master comp for that character. When I imported the psd into my project it imported with a 15 sec duration when i need it to be a full minute. I tried just clicking ctrl + K with the psd composition selected and changed the duration but it only effected the master comp for that psd. is there a way to change the duration of all the layers inside the composition at the same time so i don't have to spend a half hour doing all the layers individually?
Win 7 (64-bit)
After Affects CC(2014)
James Huenergardt
Re: How can I change a Composition and all the layers and comps inside it to the same duration.
on Jul 10, 2014 at 7:36:37 pm
Yes,
However, if you have nested comps, you'll have to change those individually.
For all regular image or solid layers, select all, go to the end of the comp and press ALT + Right Bracket or OPTION + Right Bracket.
All your layers will now be the length of the comp UNLESS you have nested comps or footage that isn't long enough.
Hope this helps.
Reel Inspirations - http://www.reelinspirations.com
Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
Joshua Chaulk
on Jul 10, 2014 at 8:12:59 pm
[James Huenergardt] "nested comps"
I assume nested comps are comps within a comp? Yeah I probably have like 40 layers and nested comps within the one comp... Guess I will have to do things the hard way.
Kevin Camp
on Jul 10, 2014 at 8:40:03 pm
there is a default duration preference for still image import in after effects.
the default usually uses the last created comp duration, but you can also set it to be a fixed duration. if you want to make sure the psd file imports in as a full minute, you can go to preferences>import and set the still footage value to 1:00:00.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
