Flare rotation
John Mark
Flare rotation
on Jul 9, 2014 at 5:43:32 am
Hello CC,
I have used the simple flare effect and want it to rotate on a circle shape layer with the clock wipe effect, similar to the 'channel ten' logo shown on the bottom right. Im not sure on how to correctly do this.
Thank you.
John Cuevas
Re: Flare rotation
on Jul 9, 2014 at 1:31:53 pm
What are you using to create your flare(AE Flare effect)? That looks like a third party flare to me, which makes things a bit easier.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Mark
Re: Flare rotation
on Jul 9, 2014 at 11:35:31 pm
Thank you all for the reply.
[John Cuevas] "What are you using to create your flare(AE Flare effect)? That looks like a third party flare to me, which makes things a bit easier.
I am using the simple AE flare which works great, But getting the rotation right, not so. I have the flare on a solid background and have used Knoll UnMult to transparent the background, I will try and set the anchor point to the centre within the circle (what George mentioned) and see how that goes.
George Goodman
Re: Flare rotation
on Jul 9, 2014 at 1:33:34 pm
If you set the anchor point of the flare to the center of the circle, you should just be able to rotate it. This of course depends on how you set up your flare effect, but that should be the general idea.
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
Tim Franklin
Re: Flare rotation
on Jul 9, 2014 at 4:17:18 pm
This is a little bit more complex than what I believe you are going for but I thought I would share this tutorial.
http://www.videocopilot.net/tutorial/the_ring/
Tim Franklin
Freelance Visual Effects Artist/ Video Editor
Media Asset Manager, CBS Sports Network
http://www.TimSFranklin.com
