Roto Brush will not render correctly because of framerate
Iris Moleman
on Jul 6, 2014 at 10:11:34 pm
I opened an AE-file I hadn't used for a while, and I got te following warning message:
'Roto Brush & Refine Edge will not render correctly because te source frame rate changed from 23,999 fps to 24,000 fps. To fix, change it back.'
I changed the framerate of the footage-layer (via 'interpet footage'), but the Roto Brush still doesn't render the right way.
I don't understand why the framerate and Roto Brush are wrong, because I didnt'ever change the framerate.
Maybe it went wrong when the project was converted to the new AE CC - 2014 format?
I hope someone can help me out,
thanks in advance.
Michael Szalapski
Re: Roto Brush will not render correctly because of framerate
on Jul 7, 2014 at 3:30:50 pm
Check your comp frame rate too (just in case).
- The Great Szalam
Iris Moleman
on Jul 7, 2014 at 9:04:02 pm
Yes, I already checked the comp framerate, but it was set to the right framerate.
I opened the project in AE CC 12.2 and that worked well. I checked 'interpret footage' and it says the framerate of the footage is 23,999 fps. But when I open the same footage in AE CC 2014, the framerate is 24, for the same footage.
Michael Szalapski
on Jul 8, 2014 at 1:11:55 pm
That's odd. What kind of footage is it? Format? Codec? Etc.
- The Great Szalam
Iris Moleman
on Jul 8, 2014 at 2:47:00 pm
It's an .mp4 file, 960 x 540, 24 fps
Michael Szalapski
on Jul 8, 2014 at 2:57:26 pm
Where did this non-standard mp4 originate? Like, from where did you get it?
Also, what happens if you import the CC version of the project file into a brand-new CC 2104 project?
- The Great Szalam
Iris Moleman
on Jul 9, 2014 at 3:52:54 pm
[Michael Szalapski] "Also, what happens if you import the CC version of the project file into a brand-new CC 2104 project?"
The same warning message shows up. And the framerate is still 24 fps, the same as when I open it as a project.
[Michael Szalapski] "Where did this non-standard mp4 originate? Like, from where did you get it?"
I downloaded it from vimeo:
Michael Szalapski
on Jul 9, 2014 at 5:04:38 pm
Try transcoding the problematic footage into a proper production codec.
- The Great Szalam
Iris Moleman
on Jul 9, 2014 at 7:53:51 pm
Okay, I'll try that. Thank you!
