Particular Newb Question
Mike MacKenzie
on Jul 6, 2014 at 5:02:00 pm
Hey everyone...
Particular newb here looking for what I expect will be a simple answer to a question. I have created rain, and am mostly happy with it except that I need to change the angle of descent to about 45° so that it looks like it's raining sideways (sort of).
This is graphic rain, so it uses a Sprite as a particle. Physics model is Bounce (so it splashes at the end). Gravity is 300. Emitter velocity is 0. I'm very happy with what I have, except that I cannot figure the raining-at-an-angle part. I assume this is a simple matter, but when I mess around with what look like promising parameters it gets all messed up. Also, my particles are basically dashes and I would like their direction to match the angle of descent.
My workaround would be to precomp the whole thing, rotate it 45° and angle the floor layer to compensate for the rotation, but I am trying to learn Particular and I'd rather do it the right way rather than fake it.
Any and all help is greatly appreciated!
Tim Franklin
Re: Particular Newb Question
on Jul 6, 2014 at 6:37:20 pm
If you transform the world on the Z axis a bit that will take care of the angle.
Then create a solid for the bounce event. I had to rotate it on the Y axis to get the floor to look right.
There might be a better way but that's what I got.
Tim Franklin
Media Asset Manager, CBS Sports Network
http://www.TimSFranklin.com
mathew fuller
on Jul 6, 2014 at 8:30:47 pm
In the physics drop down, I would mess with adding wind in the X direction.
My Work:
http://www.morecompletefx.com
Tim Franklin
on Jul 6, 2014 at 9:02:50 pm
That was my first thought too, but the bounce physics model doesn't allow for wind which is pretty limiting.
Tim Franklin
Mike MacKenzie
on Jul 6, 2014 at 9:41:31 pm
Yeah it seemed to me like Bounce was messing up wind. Guess I do need to work around.
Thanks everyone!
