How to move mask paths over several keyframes all at once?
JonZ MarZ
on Jul 6, 2014 at 2:33:31 am
I'm trying to pull a mask from a position, but unfortunately the other keyframes doesn't follow and keep morphing to the original state of the next keyframe. Is there a way to make the keyframe follows my correction?
Iris Moleman
Re: How to move mask paths over several keyframes all at once?
on Jul 7, 2014 at 9:31:16 am
Maybe you should select all keyframes before you move the mask?
JonZ MarZ
on Jul 7, 2014 at 1:21:41 pm
this was the first thing I did. The keyframe deselect once I try to move.
Brian Charles
on Jul 7, 2014 at 2:04:27 pm
Free-transform mode may help you.
First select all pertinent mask keyframes then use free-transform to modify them in unison.
http://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.html...
JonZ MarZ
on Jul 7, 2014 at 2:56:44 pm
Still doesn't work. The Keyframes stay selected but the end result after moving the mask is the same. Only the keyframe I was on was affected.
Brian Charles
on Jul 7, 2014 at 3:33:42 pm
Could you post a screen capture of your timeline and composition. Once selected, normal behaviour is that keyframes remain selected and respond to the transform.
JonZ MarZ
on Jul 7, 2014 at 3:53:40 pm
http://i.imgur.com/EwEhx4j.png
Brian Charles
on Jul 7, 2014 at 5:13:36 pm
So that looks correct. Here is what should happen.
Mask transform
JonZ MarZ
on Jul 7, 2014 at 5:30:11 pm
That's not really what I asked for. You basically did another keyframe and a newer transformation. What I meant is to move the already created keyframed mask animated tweens in the subsequent keyframes without altering the animation. I can only do it for the keyframe I have in focus, but the other keyframes don't follow. I have to transform manually every other keyframes.
Brian Charles
on Jul 7, 2014 at 5:33:04 pm
[JonZ MarZ] "move the already created masked tweens in the subsequent already created keyframes without altering the animation"
I'm not clear on what you mean. How can you move something without altering the animation?
JonZ MarZ
on Jul 7, 2014 at 5:36:34 pm
exactly my question
Dave LaRonde
on Jul 7, 2014 at 6:14:36 pm
Hmmm.... if I've been reading this correctly, here's the situation:
1) You've got a mask that's animated with a bunch of keyframes
2) After careful animation, you discover each mask is out of position, and by the same little bit
3) You need to move all the mask keyframes by the same amount, horizontally & vertically
This is a pretty easy thing to fix:
  • Put the timeline cursor on one of the Mask Path keyframes
  • Highlight ALL the Mask Path keyframes in question -- just click on the appropriate layer's Mask Path property at the left side of the timeline, and they all highlight
  • Using the up-down-right-left cursor keys, adjust the position of the mask, and they all change by the same amount.
If that solves the problem, great. If it doesn't, you'll need to re-explain your problem.
Dave LaRonde
Promotion Producer
Brian Charles
on Jul 7, 2014 at 6:22:45 pm
Thanks for chiming in Dave.
JonZ MarZ
on Jul 7, 2014 at 6:38:49 pm
Thanks for your time, unfortunately it still doesn't work. It only moving the vertices on the keyframe I am focusing.
I tried to make screenshots of what happen:
http://i.imgur.com/VESumFt.png
image 1 and 2 (from top), everything is ok. Then I want to move all the animation to another position (3rd pic), but only the keyframe I am in focus do the move and the other keyframes automatically deselect (still doesn't work with the CTRL+T transform). In the 4th pic it tweening in it original position instead of the intended new position.
Brian Charles
on Jul 7, 2014 at 8:44:52 pm
[JonZ MarZ] " but only the keyframe I am in focus do the move and the other keyframes automatically deselect (still doesn't work with the CTRL+T transform). In the 4th pic it tweening in it original position instead of the intended new position."
The keyframes in the posted images do not change position, the first keyframe remains at 0 and the second remains at 2:18.
Do you want to move all the mask vertices to a new position or move the keyframes?
Do you want a new animation tween or do you want all vertices at the new position at both keyframes?
JonZ MarZ
on Jul 7, 2014 at 8:59:43 pm
[Brian Charles] "do you want all vertices at the new position at both keyframes?"
That's what I want, by keeping the animation tween if possible. The other way around I've been reading is to create a vector shapes layer and make my animation, then link as a alpha layer.
But I never understood shapes, they aren't intuitive enough.
Brian Charles
on Jul 7, 2014 at 9:28:13 pm
[JonZ MarZ] "[Brian Charles] "do you want all vertices at the new position at both keyframes?"
That's what I want, by keeping the animation tween if possible."
When the vertices move it will interpolate a new tween. If you need to hold the vertices at a position, use a hold keyframe.
JonZ MarZ
on Jul 7, 2014 at 9:49:42 pm
but I still want the animation, I just want to change the position of all the vertices over all the keyframes. It still wouldn't let me change position throughout every keyframes regardless the interpolation I choose.
Dave LaRonde
on Jul 7, 2014 at 11:51:25 pm
This is more of a communications problem than an After Effects problem. Is this your situation:
1) You have an animated mask, and two keyframes. You have animated the mask so it gets thinner.
2) You want to move this animation to a different part of the screen.
Is this correct?
If it is, follow my instructions above. If not, find an English speaker to write for you.
Dave LaRonde
Promotion Producer
JonZ MarZ
on Jul 8, 2014 at 1:18:13 am
[Dave LaRonde] "If it is, follow my instructions above. If not, find an English speaker to write for you."
As I already explained, I already did what you suggest, it just doesn't work. As soon I move the path, whether with the keyboard arrows or with the mouse, the other keyframes deselect and only the path keyframe I'm in focus are moving. The other paths in the other keyframes stay as is.
Brandon Russ
on Dec 13, 2014 at 9:23:30 am
I found this thread because I have the exact same questions. Jonz Marz, I just want you to know you have explained it about as clear as it can be explained. I don't know why no one understands what your asking, because it makes perfect sense to me. And if had the answer I'd love to share it with you but unfortunately I am seeking the answer myself. If you figured it out, could you share it with me please? Thanks!
JonZ MarZ
on Dec 15, 2014 at 4:04:59 pm
I ended up with a different strategy since this one obviously was doomed to not work. At the end, I just made the mask animation, then move with the shape anchor point. Was less tedious than I thought it would be but still would have prefer if masked method could have worked first.
brooke qualman
on Jan 20, 2015 at 8:04:00 pm
I found a solution here:https://forums.adobe.com/thread/397813?start=0&tstart=0
You basically copy the animated path and make it into a shape layer. From there I just made the first layer alpha track matte the shape layer. You can move it around freely from there.
Dave Harrison
on Jun 16, 2017 at 5:22:40 pm
brooke's method is the only one that is doing what JonZ MarZ is asking about. It seems unbelievable that AE isn't capable of moving the mask's position over multiple keyframes simultaneously. (Highlighting all keyframes and using the cursor keys didn't work for me either, at least not on my 2013 Mac Pro, AE v. 14.2.1.34). I wonder if it did work and broke somewhere along the way.
Thanks for finding the workaround, brooke! I needed it today!
Roei Tzoref
on Jul 25, 2017 at 5:50:07 am
it's a workaround worth mentioning for some situations where global transform can solve your problem like scale/rotaion/position of all the keyframes.
you don't need a shape. simply duplicate the masked layer and use it as an alpha matte. this only solves the problem if some global transform adjustment is required, but the real problem is that you can't offset multiple keyframes like with any other parameter in Ae.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Hanker Wanker
on Mar 7, 2017 at 1:30:19 pm
Just wanted to say, that the explination of the problem was totally clear and it seams like Dave understood it perfectly on his first attempt.
The solution he gave however just istn't working. He clearly didn't test it for him self.
This is definetly a basic feature missing in AE.
Dave LaRonde
on Mar 7, 2017 at 6:52:45 pm
[Hanker Wanker] "The solution he gave however just istn't working. He clearly didn't test it for him self."
Gee, I guess the three-four times a week I have to tweak the position of an animated mask don't count.
Dave LaRonde
Promotion Producer
Sergio Andueza
on Mar 24, 2017 at 7:31:46 pm
I reached this post because I have the same problem, which is well explained, but I think the solutions you all have given are correct too. I'm attaching a video to explain it better, because I think just a few hours ago I was editing the masks selecting all the keyframes and moving them all at once but now it's not possible and it's kind of confusing. Any ideas?
Video:
Roei Tzoref
on Jun 16, 2017 at 8:14:40 pm
[JonZ MarZ] "I'm trying to pull a mask from a position, but unfortunately the other keyframes doesn't follow and keep morphing to the original state of the next keyframe. Is there a way to make the keyframe follows my correction?"
I think what Op is trying to do is offset path keyframes. like the Uberkey in Mocha.
the sad news is that in Ae it's not possible. you can't offset path keyframes. even if you select multiple keyframes, only the one your CTI is on top of will change. this is on of Ae's mask weaknesses. especially for rotoscoping. the classic example is you find out after a while that one of the vertices was not in the right place. you want to select a few keyframes and for the change to affect all of them at the same time.. no dice unfortunately.
time to go to the feature request page. care to join me? http://www.adobe.com/products/wishform.html
Roei Tzoref
Gustavo Saliola
on Jul 21, 2017 at 6:07:07 pm
Hi everyone! Let's go step by step, from last to first.
The right call is in Roei Tzoref. Is the best example of show how Adobe is wrong or lazy with this issue and how Imagineer with Mocha is right and solved it with the right programming.
The UBER KEY mode.
I use it in a daily basis and it's GOLD. It offers me the chance to modify ONCE a unlimited vertex points and this to be applied to all remaining keyframes WITHOUT changing all by hand.
By 2017, seems to Adobe had not cracked yet.
This is the issue i think this post is all about, and the goal that Dave LaRonde was not understanding (Correct me Dave if i'm wrong).
Roei Tzoref
on Jul 21, 2017 at 9:13:53 pm
you're right Gustavo in everything you wrote ;).
I am trying to advocate for this feature and have submitted a feature request. hope this will get through...
Roei Tzoref
Gustavo Saliola
on Jul 24, 2017 at 2:34:46 pm
Hi Roei! I've written too! Hope it gets addressed ASAP!
Long Live Post Production!
Nancy Sepe
on Jul 25, 2017 at 2:36:09 am
I agree that it doesn't seem to work — to move all mask keyframes at once (without disturbing position of layer itself). I'm almost sure I've done it before!
Nancy Sepe
on Jul 25, 2017 at 3:49:24 am
Brooke's suggestion worked for me.
Gustavo Saliola
on Jul 25, 2017 at 5:14:48 pm
I'm sure it's a good solution, but it's time for Adobe to address this and be in the real game like Mocha.
Every post in their request forums is a chance to be heard. Please write them!
Thanks.
Darren O'Donoghue
on Aug 31, 2017 at 11:23:46 am
Hi everyone, only just found this post after having the same issue, however managed to find a very useful tool made by David Torno via Lesterbanks website, which may save hours of painstaking searching and/or animating.
https://www.provideocoalition.com/mask-adjuster-free-after-effects-script/
Its an ingenious solution to a problem that shouldn't exist in the first place.
Hope it helps.
D
Roei Tzoref
on Sep 1, 2017 at 2:13:31 pm
Thank you Darren. it's pretty good and a workaround for some cases. of course it's not a real uber key that will enable you to offset parameters other than position... for example scale/rotation but the real mind blower is the vertices themselves like Mocha's Uberkey can do. if I discover for example after my roto is done that there is one offending vertex at a corner, if I press the uberkey I could shift it in place and the change will apply to all the keyframes.
Roei Tzoref
2D/VFX Generalist & Instructor Ae Blues Tutorials
http://www.tzoref.com
