Trying to create an expression that uses Time remapping to change frame rate of individual comp
Jay Brown
on Jun 30, 2014 at 5:15:34 pm
I need Help creating an expression that uses Time remapping to essentially change the frame rate of a comp.
I know I could just change the frame rate, but at times I need a comp to play at 29.97fps while another comp plays at half that. Or I might have one comp on odd frames and another comp on even frames.
What I have been doing is Time Remapping my comp, creating a keyframe every other frame then turning them all to hold frames. The problem is, this takes forever if the comp is greater than 10 seconds long.
Could I use an expression to do this for me?
Thanks for the help!
Walter Soyka
Re: Trying to create an expression that uses Time remapping to change frame rate of individual comp
on Jul 2, 2014 at 2:49:12 am
[Jay Brown] "What I have been doing is Time Remapping my comp, creating a keyframe every other frame then turning them all to hold frames. The problem is, this takes forever if the comp is greater than 10 seconds long. Could I use an expression to do this for me?"
Sure:
f = timeToFrames(); // get current time in frames
if (f%2 != 0) f--; // if frame is odd, decrement frame
framesToTime(f); // return frames as time
Walter Soyka
Jay Brown
on Jul 2, 2014 at 1:48:49 pm
Thanks so much, works like a charm!
I figure out that if I want only Odd frames then I just change it to this
if (f%2 == 0) f++
But I'm not really sure what this is doing
(f%2)
Could you explain to me the what the % is doing?
Walter Soyka
on Jul 3, 2014 at 2:13:49 pm
[Jay Brown] "Could you explain to me the what the % is doing?"
Gladly.
% is the symbol for the modulo operator [link], which returns the remainder after integer division.
For example, (9 % 2) is 1. 9 divided by 2 (with integer division) is 4 with a remainder of 1. (100 % 3) is 1, because 100/3 = 33 with a remainder of 1.
Even numbers are evenly divisible by 2, meaning the remainder is 0; odd numbers are not evenly divisible by 2. By checking the remainder after we divide by 2 with integer division, we can tell if a number is even or odd.
Walter Soyka
