Spirograph in 3D
Don Johnson
Spirograph in 3D
on Jun 30, 2014 at 9:12:43 am
Recently found this blog thread, looks great although I am unsure how to apply the expression?
It animates a spirograph in 3d space using the write-on effect, but I can not make sense of the expression and what nulls are required etc
http://qubahq.com/2005/08/sine-sphere/
http://aeportal.blogspot.com.au/2010/03/few-spirographs-in-after-effects.ht...
Help greatly appreciated!
Brian Charles
Re: Spirograph in 3D
on Jun 30, 2014 at 6:08:56 pm
Since Write-On uses 2D coordinates, I'm pretty sure that the expression needs to be applied to a particle system with 3D coordinates to make a 3D animation.
In the linked file I created a null named Null: Center as in the script, then I applied the script to the Null's position property, finally I linked Write-On's brush position for a 2D Spirograph and Particular's positions for a 3D one.
7695_spiro.aep.zip
The only other way might be to generate the animation in 2D and then wrap it around a sphere using CC Sphere, really pseudo-3D.
Don Johnson
on Jul 1, 2014 at 12:24:54 am
Thanks Brian,
Unfortunately I am running CS 5.5 so am unable to open your example. I have recreated my own with the position of Trapcode Particular parented to a null, with the expression copied into the nulls position. The look I am getting is not as per the example, it still appears to operate only in a 2D space.
File attached
7697_spirographattempt.aep.zip
Brian Charles
on Jul 1, 2014 at 1:00:47 am
I just looked at yours and its is 3D, add a camera and rotate it.
See this:
7700_spirocopycs5.5.aep.zip
Don Johnson
on Jul 1, 2014 at 1:29:11 am
Ah! Thankyou!
