Pre-comp opacity issue
Olly Howe
on Jun 23, 2014 at 7:57:04 am
I have a pre-comp nested within my main working composition, it contains a couple of illustrator layers, some text layers and a few shape layers. When i change the opacity of the pre comp from 100% down to 0% the layers in the pre comp are still fading out individually rather than as one complete object. It was my understanding that once multiple layers were pre comped then they should work in this way.
Am i missing something?
Daniel Waldron
Re: Pre-comp opacity issue
on Jun 23, 2014 at 3:23:56 pm
Maybe you have the Collapse Transformations box enabled? It's the little sun looking box on the same line where you would enable 3D, Motion Blur, etc.
Olly Howe
on Jun 23, 2014 at 3:37:04 pm
That's the one, thanks. Knew it would be something simple.
