Different color depth for different compositions in a same project?
Daniel Gómez
on Jun 19, 2014 at 12:39:08 pm
Hello,
I exported from Premiere to After Effects, 10 clips to a single project using Dynamic Link. Each clip is a composition in After Effects, so now I've got 10 compositions.
I want to work at 16bpc on five compositions, and 32bpc on the other five. How can I change the color depth of some compositions without affecting the rest of the project, and watch them in Premiere with their own color depth?
Thanks a lot.
Walter Soyka
Re: Different color depth for different compositions in a same project?
on Jun 19, 2014 at 2:54:25 pm
Bit depth is a per-project setting, not a per-comp setting. It'd probably be best here to split your project into two.
If you need to force 16-bit clipping between two layers in a 32bpc project, you could insert an adjustment layer with CC Composite on it.
Walter Soyka
