After effects not letting me animate
Claudia Gabriela
on Jun 17, 2014 at 7:37:29 pm
So these layers are all comps, and it has a little line across the motion blur, where normally I would be able to turn it on when animating transitions between comps. Not only that, but when i try to add a null object or a camera to animate the slide out, it does nothing.
Does anyone have any idea WTF is going on? I need to fix this asap
Brian Charles
Re: After effects not letting me animate
on Jun 17, 2014 at 7:40:59 pm
Its not clear to me what's happening. Could you post a screen shot of your timeline and comp panels?
Claudia Gabriela
on Jun 17, 2014 at 7:49:00 pm
Travis Littlefield
on Jun 17, 2014 at 8:03:45 pm
Looks like you have collapse transformations (continuously rasterize) on. If you do that you need to make sure that the objects within the various precomps also have motion blur turned on (or 3d or what have you).
Claudia Gabriela
on Jun 17, 2014 at 9:23:54 pm
FIXED! THANK YOUUU
Brian Charles
on Jun 17, 2014 at 8:08:12 pm
Layer visibility is off. Note the eyeball icon to the left of the Timeline.
