Layers starting between frames
David Gruwier
on Jun 17, 2014 at 2:23:47 pm
http://imgur.com/XXFMU2R
So this happened. I can't figure out how to fix it. If I move the layers, it just offsets, even if I hold shift to snap. Any ideas? How do I get the layer back in place?
Any ideas?
Walter Soyka
Re: Layers starting between frames
on Jun 17, 2014 at 2:25:49 pm
This can happen if you change the frame rate of a comp.
Select the layers you want to move in time, position the current time indicator to the frame where you want them to start, and press the [ (open square bracket, next to the P) key. That's the shortcut to move the in point of a layer to the current time.
Walter Soyka
David Gruwier
on Jun 17, 2014 at 2:43:03 pm
Ah! nice, I think that'd work.
Next step is to figure out how to do that on a Danish keyboard, but I think that's the solution. Thank you :)
George Goodman
on Jun 17, 2014 at 2:26:15 pm
Try using your left bracket key.
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
