RAM getting unusually overloaded
Stuart Samuels
on Jun 17, 2014 at 9:39:48 am
Hi.
I have a MacBook Pro with 8gb RAM.
Recently while working within AE the RAM has been getting overloaded VERY quickly. I have tried creating some extremely simple compositions and the problem persists. I've worked on much more complex jobs in the past without the problem, I have plenty of space on my hard drive, cleared the cache, closed all other programs, ran a memory clean program but it makes no difference.
Does anyone have any ideas why this might be happening all of a sudden and any suggestions on how to fix it?
Stuart
Walter Soyka
Re: RAM getting unusually overloaded
on Jun 17, 2014 at 2:24:17 pm
What do you mean by overloaded?
Are you seeing any slowdowns or errors, or just high RAM usage?
Walter Soyka
Stuart Samuels
on Jun 17, 2014 at 2:46:59 pm
Hi Walter.
I'm getting a lot of slowdown and very high RAM usage (up to 95%).
Walter Soyka
on Jun 17, 2014 at 2:52:18 pm
Have you changed anything on the system recently? Updated software or third-party effects?
Have you upgraded to Mavericks? Do you have App Nap turned off for Ae? What's the Activity Monitor memory pressure graph look like during a render?
Walter Soyka
Stuart Samuels
on Jun 17, 2014 at 3:40:29 pm
Yes I have upgraded to Maveriks
App nap is off for AE
The graph stays pretty reasonable but the Memory Used reaches 7.99gb of the 8 available.
The machine then grinds to a halt and doesn't recover until I run a memory cleaning app.
Todd Kopriva
on Jun 17, 2014 at 3:49:34 pm
Try enabling the Reduce Cache Size When System Is Low On Memory preference:
http://blogs.adobe.com/aftereffects/2012/10/after-effects-cs6-11-0-2-update...
After Effects team blog
Stuart Samuels
on Jun 18, 2014 at 9:12:26 am
Thanks. I'll give this a try and keep my fingers crossed.
Stuart
