Inexplicable Colour Change from AE Quicktime Render to AE Import...
Benjamin Field
on Jun 13, 2014 at 9:34:51 am
Hi All,
Using AE CS6 and I'm completely stumped by this one...
I exported a Trapcode Particular sequence to a Quicktime .mov with an alpha channel so I could re-import it into the main comp to speed things up.
This is the exported clip as it appears in Quicktime:
However, when I re-import it into AE it looks like this:
What have I done wrong...?
Cheers!
Dave LaRonde
Re: Inexplicable Colour Change from AE Quicktime Render to AE Import...
on Jun 13, 2014 at 5:40:55 pm
What media container & codec did you use to render out the particles? What's your bit depth setting for this project?
Dave LaRonde
Promotion Producer
Darby Edelen
on Jun 17, 2014 at 4:00:11 am
You didn't happen to use DNxHD in a 32bpc project did you? Alas such a pairing was never meant to be. There's a long standing problem with the way DNxHD behaves in greater than 8bpc projects.
Even if you're not using DNxHD, try using a different codec. If you need an alpha I'd recommend rendering to an image sequence unless that's out of the question.
Darby Edelen
