Graphic effect
John Mark
Graphic effect
on Jun 9, 2014 at 11:53:14 pm
Hello,
If you watch the graphic effect from 57 seconds when 2 lines appear with flares, any idea on how it can be done within after effects?
Thank you.
Tudor "Ted" Jelescu
Re: Graphic effect
on Jun 10, 2014 at 6:46:31 am
The lines with the flares can be built using Videocopilot's Optical Flare. Then you can animate the layers to bring in the lines as in the example you provided.
Tudor "Ted" Jelescu
Senior VFX Artist
Michael Szalapski
Re: Graphic effect
on Jun 10, 2014 at 2:10:09 pm
Or Knoll Light Factory.
Or any of the other lens flare plugin options.
Or you could build it with expressions and no third-party effects at all.
- The Great Szalam
John Mark
Re: Graphic effect
on Jun 11, 2014 at 1:53:12 am
Thank you both.
