Increasing timeline
Tamas Toth
Increasing timeline
on Jun 9, 2014 at 6:48:35 pm
When I first created my composition, I set the time to 1:30, but it seems I will need it a little bit longer. Is it possible to add extra time to the timeline once I started working?
George Goodman
Re: Increasing timeline
on Jun 9, 2014 at 7:21:22 pm
Go to Composition>Composition Settings and change the time there.
"|_ (°_0) _|"
Sincerely,
George
http://www.vimeo.com/georgegoodman
http://www.linkedin.com/in/georgefranklingoodman
John Cuevas
on Jun 9, 2014 at 7:36:11 pm
To add on to what George said, with the timeline highlighted in the project panel, or if it's the active panel you are using, press "cntl + K" to open up the Comp Settings. That's one a shortcut everyone should memorize.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
