Element 3D custom layer issue
Markus Yli
on Jun 6, 2014 at 5:52:18 pm
I'm having a really frustrating issue with Element 3D.
Element 3D scene setup and AE viewport doesn't match.
This happens when I change custom layer to another layer.
Let me explain:
I'm creating a AE template and I'm having this really weird issue.
I made a comp where you can put your own logo. Let's call it "LOGO". Then I add LOGO to the same comp with Element 3D to create a scene. In this comp I used AE's feature called Auto-trace and I traced the alpha channel of LOGO to a new layer. Then I added that new auto-traced layer to the Element's custom layer slot 2. Everything is working fine at this point.
Now I want to change my logo. I put a new image to the LOGO comp and traced that again in the scene comp. Now I add this auto-traced layer again to the Element's custom layer slot 2. Something really weird happens. In the AE viewport there is again the previous logo. I can't understand why this is happening. I removed the old and traced the new one. Mask changes and is correct at the auto-trace layer. Even when I go to the Element 3D scene setup everything has changed and are working just fine.
So why doesn't the AE viewport update? This totally drives me crazy.
System Specs:
Intel 2500k
MSI gtx660
8GB RAM
Software specs:
After Effects CC
Element 3D 1.6.2
Thank you!
Walter Soyka
Re: Element 3D custom layer issue
on Jun 6, 2014 at 9:11:15 pm
Try clearing the cache (Edit > Purge > All memory and disk cache).
If that works, please consider filing a bug report.
Walter Soyka
Markus Yli
on Jun 7, 2014 at 5:47:38 pm
It seememd to work with CC but I tried this same file with CS6 and it doesn't have that same button.
Do you guys know any other method to solve my problem?
Thank you very much for a good tip, Walter!
- Markus
Walter Soyka
on Jun 9, 2014 at 2:12:38 pm
[Markus Yli] "It seememd to work with CC but I tried this same file with CS6 and it doesn't have that same button. "
In CS6, there's a button to clear the cache located inside the Ae preferences.
Edit > Preferences > Media & Disk Cache > Empty Disk Cache.
You may also need to Edit > Purge > All memory.
Walter Soyka
