Rendering an Animation for Broadcast
Thom Burgess
on Jun 5, 2014 at 8:56:46 am
Hello!
Big fan of the site, and I hope you'll excuse the newbie question.
I'm currently looking to compress 4 x short 15second trailers for an Indian TV station which have been rendered in after effects. They've requested the following specs, and I'm hitting a few creative walls. The Aspect Ratio and fps I’m absolutely fine with..but I’m a little lost in terms of the rendering container and audio spec.
As I mentioned I’ve got After Effect, Compressor but I also have Final Cut Pro too. If any one can offer any assistance whatsoever I’d be hugely grateful!
TVC High Definition HD File Master
Containers - MXF for XD CAM HD422
GOP - Long GOP
Bit Rate type - CBR
Video Codec - XD CAM HD 422
Video bit rate - 50mb/s
Width -1920
Height - 1080
Frames per second -(i) 50 or (p) 25
Aspect Radio - 16:9 (Full frame only)
Audio Codec - PCM & Dolby E
Bits Per Sample - Dolby E always 20
# of Audio Channels - 4 tracks as per 1.2
Audio sample rate - 48Khz
Audio Track:
Audio Track 1 - Mono Mix
Audio Track 2 - Mono Mix
Audio Track 3 - Dolby E Mix
Audio Track 4 - Dolby E Mix
and second video
TVC High Definition SD File Master
Containers - MXF OP1A
GOP - I Frames
Bit Rate type - CB
Video Codec - IMX
Width - 720
Height - 576
Frames per second - 25
Aspect Radio - 4:3
Audio Codec - PCM uncompressed
Bits Per Sample - 24bit
Audio Track:
Audio Track 3 - Mono Mix
Audio Track 4 - Mono Mix
Lee Warner
Re: Rendering an Animation for Broadcast
on Jun 5, 2014 at 9:53:35 pm
If you have After Effects, you should have Media Encoder. One of the presets shown below should help.
Lee
SAMDOG Digital Post
Calgary, Alberta based Post Production Specialist & visual problem solver. Fluent in Avid, FCP7, Resolve, After Effects. Available for hire.
Calgary, Alberta YYC · tinyurl.com/6vgfa3f
