Is there a way to trigger a compositions start point in timeline based on the the end point of another layer.
Sumit Chaurasia
on Jun 2, 2014 at 9:13:04 am
I want to automate 'snapping' of layers rather than placing the next layer to the end of previous layer manually.
Walter Soyka
Re: Is there a way to trigger a compositions start point in timeline based on the the end point of another layer.
on Jun 2, 2014 at 2:03:21 pm
Select the layers you want to sequence in the order you'd like them to be sequenced. Right-click in the timeline panel, then choose Keyframe Assistants > Sequence layers.
Walter Soyka
John Cuevas
on Jun 2, 2014 at 2:13:51 pm
You can go to your preferences > general and switch off "Create Layers at Composition Start Time", use whatever shortcut you need to move the CTI to the end of your layer and then add the next layer.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
