make vector outlines handdrawn
bobby mcgee
on Jun 1, 2014 at 6:16:50 am
Hello,
I've made an animation using vector lines in Flash and now want to give it a more rugged look, as if sketched by hand
I start with images of this sort
then import to ae, add a paper texture below, and stylize>roughen edges for the drawing layer, giving this
I'm still unsatisfied with the result, it doesn't feel like the line is bleeding into the paper, is there anything else I can add to make it feel more real? Was Roughen Edges the best way to get the initial result?
Thanks in advance for all advice
Joseph W. Bourke
Re: make vector outlines handdrawn
on Jun 1, 2014 at 4:34:34 pm
I would suggest making a copy of the line drawing, putting it under the original one, then adding just a bit of noise, as well as a slight blur, to it. You might also try applying one of the layer modes to the layer with the effects on it (maybe Darken - play around with it). This should help out, since real ink has tiny granules of lamp black in it.
Also bear in mind that as ink is laid down, there is a certain amount of intensity loss, due to the ink load in the pen being depleted, so you might also want to introduce an adjustment layer which effects the opacity of the original as well. In that way, you'll get the intense blacks, as well as the lighter greys which are indicative of a "real" ink drawing.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
bobby mcgee
on Jun 2, 2014 at 1:39:42 am
Thank you for the ideas!
I know on top of that paper can form wrinkles around the inked areas, as here
but can't think of a way to imitate it, do you think it's possible using some combination of blurred turbulence and blending modes?
Michael Szalapski
on Jun 2, 2014 at 6:02:02 pm
Oooh, oooh, oooh!
IDEA!
Use a precomp with a layer of Fractal Noise (or Turbulent Noise or whatever) inside it as the driving force for a Compound Blur effect. You would want the details of the map in the precomp to be rather small, but Compound Blur (possibly in conjunction with a Displacement Map effect) might be exactly what you want.
Also, I'd suggest tweaking with Roughen Edges a bit more as well. You can get it to be very different from the default results with enough tweaking.
- The Great Szalam
Erik Waluska
on Jun 1, 2014 at 4:35:27 pm
To make it look like the lines are bleeding into the paper you can lower the opacity of the sketch layer and set its blending mode to Multiply.
Erik Waluska
EAWmedia
