80's Game Vector / Vectrex CRT look
Richard Lyons
on May 30, 2014 at 3:10:16 pm
Am trying to emulate a true vector line effect in AE in the style of the original CRT monitor displays on the Atari 1980's Asteroids or Star Wars arcade games. Line work drawn up in AI and imported is fine to start with but wondered if anyone can suggest a simple method to get all points where coloured lines cross over and at each corner point to create a hotter white spot, simulating the CRT effect?
Example :
Will also plan to add some glow, echo and flicker for added retroness...
Any guidance or suggestions much appreciated!
Cheers,
Rich
Dave LaRonde
Re: 80's Game Vector / Vectrex CRT look
on May 30, 2014 at 3:15:41 pm
Blend modes & glows will get you there.
Dave LaRonde
Promotion Producer
John Cuevas
on May 30, 2014 at 3:39:36 pm
You might find this script handy. LCD Effect
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jono Gaughan
on May 30, 2014 at 6:49:41 pm
For the overlapping lines, I would separate the lines into their own layers in AI, then import the AI file into AE as a composition. Set each imported layer's blending mode to "Add". That will make any overlap in the layers brighter.
For the glow, use an adjustment layer with the glow effect over top of all layers. Or pre-comp all layers, and apply the effect to the comp.
Hope that helps!
Richard Lyons
on May 31, 2014 at 8:19:49 am
Hi guy - thats all really helpful advice - much appreciated, looks like separate layers with Add TX mode plus Glow effect is the way to go... cheers
Joseph W. Bourke
on May 31, 2014 at 1:36:22 pm
Also check this one out - a new freebie from Video Copilot called Color Vibrance - looks like it might make the process quicker:
http://www.videocopilot.net/blog/2014/05/new-plug-in-color-vibrance/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
