DuiK elbows!!
jim lefevre
DuiK elbows!!
on May 29, 2014 at 1:15:50 pm
I am so wonderfully in love with DuiK, the Inverse Kinematics tool developed by Duduf and have used it for years now but I keep forgetting the 'elbow' frustration and was wondering if anyone had found the same and had managed a workaround?
Essentially the IK works a treat in creating comprehensive jointed puppets but when moving the hands (to move the arms) there are points where I would like to adjust the placing of the elbow which has its rotation locked into the most amazing ream of scripting which I just can't unpick!
I've noticed that Duduf's updated his site so I'm going to pop in and see if this has been evolved but was wondering if anyone else had come to the same problem (and solved it!!)
Thanks!!
Jim
http://www.jimlefevre.com
Brian Charles
Re: DuiK elbows!!
on Jun 5, 2014 at 11:20:28 pm
Duduf's IK uses a lookAt expression tied to the controller layer's you create with the script.
I'm not sure what issue you're having with the elbow's. Duduf has some new tutorials with English sub-titles that explain the basis of the script.
http://duduf.training/?p=692
Daniel Cantwell
Re: DuiK elbows!!
on Aug 31, 2016 at 12:38:57 pm
Hey! I know this was posted a while ago but I'm going to put up the solution I've found as I was looking this morning for an answer to this and there is very little on the interwebs about it. If you make a regular IK Chain,ie. puppet pin you arm in shoulder,elbow and wrist, select the layer and hit bones, parent wrist to elbow and elbow to shoulder click your wrist null and create a controller for it, select shoulder,elbow,wrist nulls along with wrist controller and hit IK. Once this is complete and you have a normal ik chain, duplicate the elbow controller and rename it elbow manipulator or whatever you want. Delete all the Ik in the effects panel, rotation and position and then match the position and rotation of the original elbow controller. Select your new elbow controller go to solid settings and make it twice as big pixel wise as your original so you can easily differentiate between the two. Parent this new controller to the original elbow controller with all the ik junk in it. Go into your puppet pins on your arm and in the elbow puppet pin rename the target in the expressions from the original elbow controller to your new one. Now you will still have all your original IK functionality with the addition of being able to freely move the elbow. Hope this helps.
jim lefevre
Re: DuiK elbows!!
on Mar 27, 2017 at 1:43:51 pm
Ha ha!
Did a search for this AGE OLD problem and found this thread which I actually started! How funny!
Daniel... This sounds so super exciting but I can't seem to get your instructions working... halfway through you mention an 'elbow controller' but I can't find where you mention creating this. I don't suppose you could clarify?
Shall keep re-reading and seeing if I can get it working. If it does then you are an absolute star!!!
(might DM you if this reply doesn't flag up on your radar)
Jim!!!
Daniel Cantwell
Re: DuiK elbows!!
on Mar 28, 2017 at 11:56:46 am
Hey Jim
Sorry for not explaining myself better. I've made a video which will hopefully clear things up.
https://f1.creativecow.net/file/11197/11197_elbowcontrolduikhd.mp4.zip
Let me know if you have any problems.
Thanks.
Daniel
jim lefevre
Re: DuiK elbows!!
on Mar 30, 2017 at 5:26:36 pm
Thank you so much for that tutorial, that was extremely thoughtful to record.
I cannot tell you how much you have changed my life - it works and it is absolutely brilliant. I wonder why Duduf hasn't implemented this as part of the script as it sorts out so many problems. My characters can now drink things!!
Thank you thank you!
Jim
Daniel Cantwell
Re: DuiK elbows!!
on Mar 30, 2017 at 5:57:48 pm
No problem Jim, glad I could help. đź‘Ť
Logan Penciu
Re: DuiK elbows!!
on May 24, 2017 at 7:56:04 pm
Hi there!
I watched you're video and I understand your solution for a IK rigged arm. However I'm flat out not good enough with expressions to understand how to take this technique and adapt it to an auto rigged arm.
In my project my character needs to move its limbs in a more realistic fashion (i.e. not rubber hose and bendy limbs). How can I create an IK elbow goal for an auto-rigged character. I need elbows and knees to have a controller that lets me adjust their orientation just as a 3D rigged character would have.
Using an auto rig makes it so I don't make puppet points, I just simple pre comp all the body parts, adjust their anchor point where I want it to pivot and bend and it just spits out controllers with no exact bone/controller on the elbow itself. So I can't replicate what you did in your video tutorial, as well as the expression on the controller/parts is not the same syntax as what I see in your video so I don't know where to replace words.
Could a step by step explanation be written out for me or a video tutorial of how to make an elbow/knee goal for an auto rigged bi-ped human? I can't find anything online about how to do this in AE and DUIK but it's so simple in a 3D application.
miritte ben yitzchak
Re: DuiK elbows!!
on Mar 17, 2018 at 9:53:10 pm
Hi Logan,
I know this is an old thread, but I'm wondering if you found a way to do this as I have been searching everywhere and can't seem to find a solution (still learning AE and DUIK)...
I have auto-rigged my character, and it all works fine until I try to lift the character's hand - I am trying to position the hand next to its ear as if listening (or lift the hand to drink), but at a certain point the elbow "jumps" up rather than stay positioned down, so it looks very unnatural.
My question is - is there a way to add an elbow controller to an auto-rig so that I could control the position of the elbow when animating an arm? I have seen it done with puppet pins and bones, but couldn't find a way to do this with an auto-rig.
I will appreciate any tips on how to do this!
Thanks, Miritte
Fons Martens
Re: DuiK elbows!!
on Feb 1, 2018 at 11:03:21 am
This was amazingly helpful and very simple to boot!
Thanks a bunch!
