Script Baffle - Extend nested comp durations?
Cameron Walser
on May 27, 2014 at 8:34:04 pm
Hi people -
I select one comp, extend its duration and then have all of its respective layers automatically extend as well, recursively. I searched these forums and found references to "Compsetter," but it doesn't exist anymore. Then I found SelectedCompsChanger, which works great, but requires you to select every comp and layer that's nested, which is very difficult, to say the least. ( i guess I could do a reduce project as a work-around, but seems a bit roundabout).
Also found a script whose top commments are
//Byron Nash, edited and improved by Paul Tuersley
//Nov. 2004
//Set all precomps and comps in to main comp's duration
//Select a comp or have it as the active item
//Script will change the length and out point of all comps and stills to the length of the current comp
But this doesn't seem to work in CC....
Anyone have an After Effect CC solution to this problem? Could it be just a matter of modifying the Byron Nash script?
thanks!
cameron
Jason Jantzen
Re: Script Baffle - Extend nested comp durations?
on May 28, 2014 at 3:12:58 pm
Here you go https://www.dropbox.com/s/s648gttjhdreo3w/rd_compsetter_v3.0.zip
Jason Jantzen
vimeo.com/jasonj
Suresh Kavan
on Sep 13, 2014 at 8:32:09 pm
would it be possible to repost this tool as the link seems to have died. Thanks.
Jason Jantzen
on Sep 13, 2014 at 9:17:29 pm
He's posted all of his scripts just recently in hopes that you will donate to a cause.
http://www.redefinery.com/ae/rd_scripts/
The script in question is RD_compsetter.
Jason Jantzen
vimeo.com/jasonj
