How would I add Milliseconds to this expression?
Jackson Redshaw
on May 26, 2014 at 5:54:11 am
Hi Guys,
Just wondering how I would add milliseconds to this expression?
rate = -1;
clockStart = 388;
function padZero(n){
if (n < 10) return "0" + n else return "" + n
clockTime = Math.max(clockStart + rate*(time - inPoint),0);
t = Math.floor(clockTime);
min = Math.floor((t%3600)/60);
sec = Math.floor(t%60);
min + ":" + padZero(sec)
Jackson
http://www.youtube.com/MITLRproductions
Dave LaRonde
Re: How would I add Milliseconds to this expression?
on May 26, 2014 at 6:10:25 am
At what frame rate do you need to deliver your finished work? If it's one of the standard rates, whether you have the ability to add or delete a few milliseconds or not is irrelevant.
Dave LaRonde
Promotion Producer
Jackson Redshaw
on May 26, 2014 at 6:14:29 am
Hi Dave,
The frame rate is 25. At the moment, only the minute/s and second/s are displayed on the screen
Jackson
Jackson Redshaw
on May 26, 2014 at 1:14:31 pm
I think you misunderstood the question, entirely my fault though.
The expression is generating a countdown clock on the screen. But only the minute/s and seconds are displayed.
Thnaks
Jackson
Walter Soyka
on May 26, 2014 at 1:26:45 pm
rate = -1;
clockStart = 388;
milliseconds = clockTime.toFixed(3).split(".")[1];
min + ":" + padZero(sec) + "." + milliseconds;
The magic happens here:
Here's a translation. toFixed() is a method that converts a number to a string with a fixed number of decimal places (in this use above, 3). It will pad with zeroes as necessary to maintain this fixed number.
split() is a method which splits a string into an array of substrings when given a separator. In this case, the separator is a period. For the string "0.123.456", split(".") yields this array of strings: ["0","123","456"]. We use array indices to access a specific substring.
In plain English, the above line says convert the clock time to a string including 3 decimal places, then take only the digits after the decimal point and call them "milliseconds."
Walter Soyka
Jackson Redshaw
on May 26, 2014 at 1:28:37 pm
Thanks so much Walter. Worked Perfectly!
Jackson
