Creating an advanced morph transition
Tim Baas
on May 23, 2014 at 1:52:08 pm
We've got a couple videos shot in different times of the year but the movement is almost the same each time.
Because the videos are shot with a drone the videos are not exactly the same in movement and therefor I'm not able to use a simple opacity transition.
I need something like they use when transitioning photos of faces from one to another, where it seems the pixels are moving to the correct place (?).
Do you guys understand what I mean? Anyone knows the way to do it?
Walter Soyka
Re: Creating an advanced morph transition
on May 24, 2014 at 11:51:09 am
The easiest way I can think of to approach a morph like this is with RE:Flex from RE:Vision Effects:
http://revisionfx.com/products/reflex/
If you want to do this without third-party plugins, you can use the Mesh Warp or Liquify effects to distort the two images so they match.
Walter Soyka
Tudor "Ted" Jelescu
on May 26, 2014 at 7:06:46 am
For a all AE morph technique read this post:
http://forums.creativecow.net/readpost/2/992175
Your morph is more complex but the idea is the same.
Tudor "Ted" Jelescu
Senior VFX Artist
