Enterance effect on lower third
Brandon Adam
on May 20, 2014 at 10:43:24 am
Hello experts,
Not very familiar with the shape tool and its features and in need of some help. I'm trying to create this similar effect for when the lower third enters the screen. Any idea on how its done?
- 20 seconds.
Thanks in advanced.
Dave LaRonde
Re: Enterance effect on lower third
on May 20, 2014 at 3:13:42 pm
The heavy lifting in this is done with animated track mattes. The colored part doesn't move; you could do it with a shape or with a solid and a mask to define the dimensions.
Dave LaRonde
Promotion Producer
Brian Charles
on May 20, 2014 at 3:21:46 pm
*EDIT* : Dave you beat me to it, as usual.
One method is to use a track matte on the Lower Third.
I've approximated the reveal you've indicated in this sample file:
7522_mattedlowerthird.aep.zip
Brandon Adam
on May 20, 2014 at 9:51:58 pm
Thank you both for your help! Brian, how did you create the semi circles?
Brian Charles
on May 21, 2014 at 1:14:24 am
Made it in Illustrator, copied and pasted to a shape layer in AFX.
