Text layer disappears when an effect is applied
Charlie Nancy
on May 20, 2014 at 12:34:17 am
I have a text layer which is motion tracked to a null object, and is also attached to a track matte mask. As soon as a drag a blur onto the text, even if the blur is still set at zero, the text completely disappears. Is this a bug or am I doing something wrong?
Evan Robinson
Re: Text layer disappears when an effect is applied
on May 20, 2014 at 1:38:34 am
Did you try pre-composing the text layer?
E. Robinson
Charlie Nancy
on May 20, 2014 at 2:31:50 am
I didn't no - that solved the problem! Thank you.
Evan Robinson
on May 20, 2014 at 4:03:02 am
No problem, glad it worked.
E. Robinson
