Make both handles on keyframe move together?
Jonah Coltrane
on May 19, 2014 at 1:13:55 pm
I'd like to make it so when I move the handle on one side of an easy eased keyframe, it moves the other side to make it so both handles form a straight line.
Jonah Coltrane
Re: Make both handles on keyframe move together?
on May 19, 2014 at 1:48:27 pm
I figured out the solution! I right clicked on a keyframe in the graph editor, clicked "Keyframe Velocity" then checked "Continuous (Lock incoming to outgoing)". I hope this helps anyone that has the same problem!
John Cuevas
on May 19, 2014 at 1:56:10 pm
Right click the keyframe, select Keyframe Interpolation and for Temporal Interpolation, choose Continuous Bezier.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
