card wipe query
chris brett
card wipe query
on May 16, 2014 at 6:22:08 pm
Hi
- 2 queries about card wipe transitions - any insight on this would b much appreciated.
1 ) Is it possible to get a real 3d cardwipe without actually building your own ? --- very interested in something like this that responds to the light with reflections / specularity and cast shadows.
2 ) Is is possible when using the AE version of cardwipe to set it so that there are 'no lights' ie image remains tonally unchanged -
---feel like I'm looking for a 'no lights button' and cant find it - result is slightly shaded round edges - not really noticeable but dulls caption and also needs to match untreated version in the comp.
--------------------------------- chris --
Dave LaRonde
Re: card wipe query
on May 16, 2014 at 7:35:47 pm
Are you SURE you can't disable the lighting? It's been a long time sine I last used Card Wipe, but I don't recall lighting problems.
Who knows? Maybe I just moved the lights completely off the image, or turned off specularity, made the lighting all-ambient... in any case, it wasn't a big deal. I'd check it again.
Dave LaRonde
Promotion Producer
chris brett
Re: card wipe query
on May 16, 2014 at 8:09:33 pm
Hi Dave
--- thanks for speedy reply ....
...... its not a problem as such its just that it doesnt match original so there is a jump in levels when I go from one to the other --
------------ will take another look maybe you are right -- it cant be that tricky ....
------------------- regards -------------- chris --
Brian Charles
Re: card wipe query
on May 16, 2014 at 9:54:02 pm
Card Wipe simulates perspective with shading, try increasing Ambient light and decreasing Light Intensity.
chris brett
Re: card wipe query
on May 16, 2014 at 10:04:50 pm
thanks Brian I will give it a try -- all the best ----chris --
