Mocha Pro - Matte Clips
Riccardo Sinti
on May 16, 2014 at 4:59:00 pm
I'm trying to import a matte clip to use instead of splines.
Everytime i import an mov (8bit 256 greys) I get a dialog that says mov must be converted to 8bit grey scale to use as matte clip.
When i go to clip module all i see is black.
Any advice on using mate clips?
Dave LaRonde
Re: Mocha Pro - Matte Clips
on May 16, 2014 at 11:56:20 pm
We need to know the codec and media container (mp4, mov, avi, etc.) of the clip -- plus your version of AE -- before we can give good advice.
Dave LaRonde
Promotion Producer
Riccardo Sinti
on May 18, 2014 at 12:03:01 pm
First I tried prores out of AE6.
Then I tried lossless 265 greys 8bit.
I also tried a jpeg sequence.
Mocha Pro always indicated that the clip would have to be converted to 8bit greyscale. There is a checkbox in the clip module to convert to 8bit so I checked that anyway.
Nothing happens.
I haven't been able to find much more than a mention in the Mocha doc that you can import a matte clip to replace splines on a layer.
I haven't seen any tutorials that use matte clips.
Anyone see any out there?
Ross Shain
on May 19, 2014 at 5:01:37 pm
The key to importing an external matte clips is to create a mocha layer and make the shape cover the entire image area, then select the layer properties and insert a Matte Clip. mocha will read the matte and you will know it is working if you see the matte in the overlays.
Hope this helps.
Ross Shain
Imagineer Systems
http://www.imagineersystems.com
Riccardo Sinti
on May 19, 2014 at 5:31:28 pm
Well, I wasn't covering the entire image with a spline to make the layer, so I did that but still the matte clip does not show up after I import.
When I go to the clip module the name of the matte I imported is in the drop down but when selected all I see is black.
Is there a particular codec that is preferred?
Is there a tutorial out there that utilizes this feature so I can see it in action?
Riccardo Sinti
on May 19, 2014 at 5:43:17 pm
Ok, I used an SGI sequence and it finally worked.
