Keying an object while giving it a stroke
caleb barclay
on May 15, 2014 at 8:33:48 pm
I'm looking to put a stroke outlining a moving hand. I have Color Keyed the hand but I don't know where to go from here. Is there any way to:
1. Outline object by (x) pixels?
or 2. Add stroke to Keyed object?
I don't want to just make a duplicate hand and scale it behind the original and make it blue. Any ideas?
Michael Szalapski
Re: Keying an object while giving it a stroke
on May 15, 2014 at 8:42:41 pm
You could try the Vegas effect using the alpha of the hand layer.
Or Glow.
In either case, you would need to modify it to make a hard line instead of a fading one, but you can do it!
- The Great Szalam
Dave LaRonde
on May 15, 2014 at 9:12:10 pm
There's another good trick to do this using Auto Trace.
You key the subject. There can be noise in the subject as long as it's a good key, it doesn't matter. Then you use Auto Trace, applied to the alpha channel. The result: an animated line around the edge of your subject... and it's separate from the subject layer. Very handy.
Dave LaRonde
Promotion Producer
Kevin Camp
on May 15, 2014 at 9:21:25 pm
and another...
layer>layer styles>stroke.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
