Error rendering while using True Comp Duplicator
Sara Nunes
on May 15, 2014 at 5:06:12 pm
Hi.
I'm using true comp duplicator script in my project and when I'm rendering it gives me the following error, Afer Effects erros: Image Buffers of 23740 x 23741 @ 8 bcp(2.1GB) exceed internal limits...
I increased the RAM for AE and run cccleaner but keeps appening.
When I shut down the comps with True Comp Duplicator layers renders just fine.
I'm using CS5 version
Can you help?
Thank you very much
Todd Kopriva
Re: Error rendering while using True Comp Duplicator
on May 15, 2014 at 5:41:45 pm
The RAM required for rendering of that frame exceeds the maximum size of an image buffer in After Effects. You need to decrease the RAM requirements for rendering that frame.
Without knowing details of the composition, we can't know what's requiring all of that RAM. It could be that you're zooming way in on a large layer; it could be a camera move; it could be an effect; etc.
After Effects team blog
Sara Nunes
on May 16, 2014 at 10:23:25 am
Thank you very much for your help.
I had a repeater animator on a shape with too many copies.
Problem solved! :)
