After effects painfully slow on my mac pro
emil peterson
on May 15, 2014 at 1:56:17 pm
Hello everyone
I've bought a mid2010 mac pro with these hardwares:
Intel xeon 2 x quad core = 8 core
16gb ram
ati 5870 graphics card
but now when i trying to render different files ( videos - projects ) in after effects is very very painfully slow
i tried in different settings in render and also tired the multiprocessor on/off , disk cache but there was no difference in result
I know there's a real problem because my old IMAC with 4gb ram and amd6750M graphic , intel i5 cpu , is 2-3 times faster than my mac pro in after effects
if you knows how to fix it help me please because i bought this mac pro to to do big projects but now my old imac is 2-3 times faster than it :(
Paddy Uglow
Re: After effects painfully slow on my mac pro
on May 15, 2014 at 2:16:26 pm
Have you been into AFX preferences and switched on the multi-threading option (it's called "Render Multiple Frames Simultaneously" is CS6? I ticked the equivalent in CS3 on my macbook and it sped up rendering substantially.
Which operating system are you running? I have strong suspicions that my Mac Pro slowed down a lot when I put 10.7 on it. It's a 2x3Ghz quad core xeon with 12GB ram, but my 10.6 2011 2.1Ghz 8GB RAM MBP compresses video from Quicktime Pro at about 70-80% of the speed of the Mac Pro.
Paddy, CreativeMedia.org.uk
emil peterson
on May 15, 2014 at 2:36:53 pm
yes i've changed that setting but there was no diffrence on final
my os is the latest 10.9 maverics and my after effects is cs6
when i googled the problem i saw many of people have same problem !!
so what can i do now
Walter Soyka
on May 15, 2014 at 2:51:54 pm
[emil peterson] "my os is the latest 10.9 maverics and my after effects is cs6"
Have you turned off the Mavericks "App Nap" feature for Ae?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Walter Soyka
on May 15, 2014 at 2:17:09 pm
Without knowing any of the specifics about what you're doing (what your projects are like, what renderer or effects you're using, what your render times are, what version of Ae you're using), it's hard to give you specific advise.
Here's some general advise: 16 GB of RAM is not a lot for 8 cores. I'd suggest you double that to 32 GB. Right now, most of your CPU power is sitting idle for lack of RAM.
You should turn multiprocessing on. Try leaving 6 GB free for other apps. Try allocating 3 GB per background process. Leave half your CPUs free (not that it really matters here -- with this little RAM and with these memory settings, Ae will only start 3 render processes anyway).
Walter Soyka
emil peterson
on May 15, 2014 at 2:56:08 pm
my aftereffects is cs6 and my os is the latest maverics 10.9
i tried in different projects with 3d effects and without , also i've a blackmagic 2,5 k cinema camera
when i import the camera's raw files in IMAC i can export them 2 times faster than mac pro!!
and tried with multiprocessor and without but there's no difference in final
emil peterson
on May 15, 2014 at 3:12:03 pm
for example i bouhgt an ae project from internet
in imac the render time is 4 hours but in mac pro is 6 hours
Walter Soyka
on May 15, 2014 at 4:01:48 pm
Again, does it make a difference if you disabled Apple's App Nap feature for the Ae application?
http://helpx.adobe.com/creative-cloud/kb/app-nap-reduces-application-perfor...
Walter Soyka
Nasir Sohail
on Jan 31, 2017 at 8:30:18 pm
I had this same problem with After effect, premiere and photoshop that they were literally crawling with a beachball sign every now and them. I found that both the indexing and Time machine backup was working together and they were eating up almost all the cpu threads causing the system wide slowness.The time machine was stuck for some reason. I read this post on Fix slow Mac after upgrade and followed the steps mention in there and now it works perfectly fine.
