Ramp up effect working oddly.
Ren Junz
on May 15, 2014 at 3:44:06 am
I've tried this multiple times, using multiple files and looking at numerous threads to no avail.
I only get half the animation, I want each letter to come in individually at different times so I used the "Ramp Up" feature of a Range Selector.
Please help me ASAP because this has been bothering me for a long time.
Darby Edelen
Re: Ramp up effect working oddly.
on May 15, 2014 at 5:08:44 am
When using a Ramp Up or Ramp Down selector shape you'll generally want to animate the Offset instead of the Start and End values.
For example, if your start and end values are 0% and 100% respectively then you'd animate your Offset from -100% to 100%. If your start and end are 0% and 50% then you'd animate your Offset from -50% to 100%.
The Offset is what actually slides the ramp through the characters. The Start and End values only define the width of the ramp.
Darby Edelen
Ren Junz
on May 16, 2014 at 1:43:25 am
Thanks but when using this feature it doesn't look very smooth.
If anyone can help me further.
The whole animation does not go through the "t" but I would like it to.
I have no idea what to do.
